M50 Stoker Turbo
  • ///MLIFE
    • Feb 2012
    • 94
    M50 Stoker Turbo
    So I'm picking up a complete M50TUB25 swap as well as and a M52B28 bottom end this weekend. I'm thinking of either options:
    1.M50 Head just bolted on the M52 bottom end. Thus having a OBD1 M52 essentially. What kind of CR would I be looking at and what thickness HG would I use? I've heard of people doing this for stroker NA builds and being ~11:1 but I'm not 100% sure.
    2. M50 Head and M50 block w/ M52 crank/rods/pistons installed. Making this a M50 stroker of sorts. I was also told the side walls of the M50 were thicker than the M52 but I thought they were essentially the same block?
    Then, the plan would be:
    ARP Head Studs and Rod Bolts
    .140 MLS (Or whatever would work to lower CR)
    60 lbs Siemen Deka Injectors
    Walboro 255
    Megasquirt or a ROM tune
    For turbo selection, I was thinking may an HX35 (cheap route) or possibly a GT3076/3582/Precision6262 or some equivalent BB turbo with a decent spool. I'd love to hear what everyone else runs and if possibly dyno sheets to compare spool of different turbos and setups.
    Looking at other threads on an HX35 at 18psi I should be able to put down about 400 with a proper tune. I've seen people "reliably" run up to 21psi and be somewhere around 450 or more (before you bend a rod at 500)
    The plan is run this (and pray it doesn't blow up) until I'm out of school and can actually put pistons/rods in the motor and no cheap out. Thanks for the input R3V; I'm excited to soon join the 24V Turbo crew :D
