alright, here is one for you guys that have done an obd1 swap onto an s52:
i have the crankcase vent connector (the one that attaches to the valve cover and has 2 outlets) from an obd1 motor. however, it is too big to fit into the hole on the valve cover on my 98 s52 motor. that crankcase vent has only one big outlet and is shorter. does this mean i have to get an obd1 valve cover (not coil cover) for my motor? i didn't think that was a necessary step and that the only mod to the valve cover needed was to dremel out the recesses for the coil wires. help!
