more questions: fuel evap system with diagram
    Is #1 in the above diagram the fuel evap switch?
    Where does it mount on the motor?
    Does the hose in #12 go to the small outlet on the crankcase breather?
    Figuring out where everything goes with only the parts diagrams to go on is fun!
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    yes, #1 is the evap purge valve switch. plugs into wiring harness.
    it mounts under the intake manifold, on a small metal bracket. look at the purge valve, it should have a rubber holder around it. on the rubber holder, there is a slit to slide over the tin metal bracket.
    no, #12 shows the alternative to piping the valve. its either a direct hose from tbody to evap sw, or it has the inline valve like #12 shows.
    good luck, cheers, jason.
      thanks! so does the small hose fromt he crankcase breather go to the charcoal filter? if not where? thanks again.
        haha oops. i "deleted" my charcol canister.
        Dan
