1.
If anyone has a peake code puller maybe you would know this.
When I pull codes it gives me "FF" as my car model, the book thats that means it cant determine the engine through the code reader. I am supposed to look it up manually. I dont know which exact model I should be looking at. I have a s52 with OBDI, but everything under "m3" is listed under the K5 table. I keep getting code 24 (IIRC) for the speedo sensor. But it is all hooked up? Im not having any issues with it how I used to. I looked on the K6 table, and 24 is listed as a knock sensor. Which one is it??
2.
I have a conforti chip in my car, I was under the impression that I would still get a rev limiter if I went high enough. I was stomping on my car a while back and since my tach is incorrect I was just going to let it go until my rev limiter kicked on so I could see where it all lined up. But I can push it so far up in the RPMS the engine almost stops. I can feel the power just quit on me, like riding a bike and someone just jammed a stick in your front wheel lol. I hope I didnt break anything.
2.
