Shimming up engine
  • Steven
    • Dec 2012
    • 2305
    Shimming up engine
    Does anyone know how much you can space up the engine on swapped cars? I read somewhere 5/8 but I'm not sure about interference with the hood?
    Feedback!
    Custom Cup Holder Consoles!
    Calypso Story--S50/Shaved and Tucked Bay
  • camshaftgsxr
    • Aug 2011
    • 416
    what are you trying to clear? assuming you are using m5 mounts or some other type or "stud" mount you can space it to the top of one stud without any problems, mine is spaced that much (maybe half an inch) and doesnt rub the hood insulation. i had to do it to clear the factory booster after moving it over the half inch already. i just used steel washers which some may think is ghetto or cheap but i can adjust it up an down in increments if i ever need to.
    if you mean to move it up to avoid buying a skid plate, dont, that 5/8ths inch isnt going to save your oil pan.
    BroWorks.com Bro is a lifestyle
    • Steven
      • Dec 2012
      • 2305
      It is to save the oil pan. 5/8" will make a huge difference in clearance. At least until I can find someone that makes custom pans...
      Feedback!
      • camshaftgsxr
        • Aug 2011
        • 416
        www.raceskids.com
        they make a 24v plate, donno if you meant true custom though.
        • Steven
          • Dec 2012
          • 2305
          www.raceskids.com
          I meant a custom oil pan
          Feedback!
          • Neil1138
            • 527
            I had to shim up the passenger side only, about 1/2", to give clearance for the downpipes against the subframe. No clearance issues between the engine and the hood (and I have the oem heat shield in place).
