S50 Intermittent Surging and CEL problem
  • M3PO
    • May 2012
    • 537
    Hey guys, my S50 swapped car has a weird issue. Occasionally when I am accelerating normally in 1st, 2nd, and 3rd my CEL will come on for a second at about 3K RPMS, then go off. It does it in each of the three gears but not 4th and 5th. It doesn't happen often and the car acts normal so I don't know how to diagnose it.
    The other problem is that occasionally if I'm cruising along in in traffic at moderate speeds and constant throttle (2500-3000 RPMs), the car will lurch or surge. Again, it's very intermittent.
    The car runs great otherwise. Except sometimes it feels like it's a little bit down on power (old knock sensors?). I also have a slight miss at idle.
    Ideas? Thanks guys!
  • sweet3
    • Oct 2012
    • 751
    could it be your vanos?
    Have you tried "stomp test"? It might throw a code
    PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
    • M3PO
      • May 2012
      • 537
      My VANOS is noisy, I know that for sure. I tried the stomp test when I finished the swap but I was under the impression that it wouldn't display a code unless the CEL was already lit.
      • mpowerful
        • Jul 2013
        • 1273
        It stores codes.
        • M3PO
          • May 2012
          • 537
          Stomp test revealed P1226, which the internet says is for the knock sensor. I will report back after I swap them out.
          • amcink
            • 788
            Becareful with 1281 then you need a new DME
            • M3PO
              • May 2012
              • 537
              Not sure what you mean. It never threw 1281.
              As an update, the rear knock sensor was busted all to hell. CEL has not reappeared. I haven't experienced the surging again either.
