So Im almost done with my swap, I used the revshift adapter guibo but it doesn't fit correctly since I have a closed flange and not the recommended open trans output flange. So now I'm looking for a driveshaft. I know it has to be a 96+ 328i or m3 driveshaft. Can it be from either an automatic or manual car? Needs to have a 4 bolt rear correct?
Driveshaft?
Tags: None
Sorry for the late reply but I figured everything out! I just used my revshift guibo, I had to notch my flange in order for the bolts to fit. Thanks for the replying, I just wasn't sure if people had been successful using auto driveshafts!Comment
What if you use a getrag 250? Couldnt you use an e36 325i manual driveshaft and put in a flipped e30 center support bearing?
