how much HP can a stock fuel pump support?
  • bimmers4life
    • 420
    how much HP can a stock fuel pump support? i have a 91 318is and would assume that the fuel pumps are the same for all non M e30's. Thanks!
    -Richard
  • gstuning
    • 833
    all E30 pumps are the same and you will be fine unless you reach more then 350-400hp
    Gunni
    @ Prodrive / Aston Martin Racing
    • 1990m3
      • 1180
      '91 318is has a proprietary fuel pump. Although it may flow the same it is different from all other e30 fuel pumps.
      • bmw332i
        • 229
        I'm still running a stock e30 325i fuel pump, and I'm making over 330 crank hp from my fully built s52. I would assume that that would be enough unless you plan on turbo-ing your car.
        • bimmers4life
          • 420
          What exactly does that mean? i dont know a whole lot about fuel pumps.
          Sounds good though. That is one less thing i will have to worry about!
          • 1990m3
            • 1180
            it has something to do with the fuel hose connections at the top of the fuel pump. I have a new one sitting here right now that I have to install as mine is dodgy.
