Silver sludge on drain plug?
  • Luke_M
    • Aug 2011
    • 275
    Every time I change the oil I get this silver sludge on the magnetic drain plug. It's very soft, doesn't feel gritty but it's still concerning especially given that it's a euro s50 that was raced. Rod bearings are a big concern.
    It's always had redline oil and is daily driven now but i still have gotten the silver looking sludge for 4-5 consecutive oil changes since I've owned it. I'm gonna do a UOA next oil change fwiw.
    Anyone experience this or have any ideas?
    Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
  • mpowerful
    • Jul 2013
    • 1273
    Sounds like bearing lead. Id have oil analysis done asap.
    • The Dark Side of Will
      • Jun 2010
      • 2796
      It's a good idea to do an oil analysis at EVERY oil change so that you establish a history for your engine... Yes, you should do analysis ASAP. Don't wait for your next oil change.
      • M3PO
        • May 2012
        • 537
        Lead is not magnetic lol
        The most common sources of iron in used oil are cylinder walls, piston rings, and cams.
        • Luke_M
          • Aug 2011
          • 275
          I was thinking that as well. The only part of a bearing that is magnetic, as far as I know, is the steel backing. I could be wrong however. I'm not certain of all the layers bmw uses.
          Either way, not exciting.
          • M3PO
            • May 2012
            • 537
            You are correct, you would have had to wear through to the steel backing. Old rod bearing used to be copper and lead, newer bearing since 2010 can't have lead in them per EU laws so they are now tin and aluminum I believe.
