Automatic m50b25, what are these wires for?
  • Slider
    • Jan 2013
    • 10
    This motor was pulled out of an early automatic e36 with a green 103 DME. Trying to figure out which wires can be eliminated, does anyone know what these wires are for, the ones in the 3 black housings?
    Thanks!
  • Need4Speed1299
    • Oct 2007
    • 119
    I have the exact same issue. I have a 413 dme, and a vanos obd1 auto harness, but manual trans. Im pretty sure we need to keep a few wires from that bundle for the o2 sensor. The rest I believe are for the auto trans.
    • Slider
      • Jan 2013
      • 10
      Yeah started going through it today, it looks like 2 of those bundles go to the automatic computer, and yeah I was kind of guessing one of those is the o2 sensor wires. Just gotta figure out the colors, I've been using these manuals: http://wedophones.com/BMWManualsLead.htm
      From what I see all the connections are the x20 connector, and the only one that needs to be hooked up from the automatic computer is the brown/black which energizes the starter relay.
      • Need4Speed1299
        • Oct 2007
        • 119
        Thanks for the link. I wonder if thats a neutral safety switch, or a foot on the brake type of switch.
        • Slider
          • Jan 2013
          • 10
          Neutral safety it disables the starter if you're not in park or drive, you could also bypass the starter relay, either way will work.
          • mpowerful
            • Jul 2013
            • 1273
            You can cut out all of that except the o2 wires. You need to put a plug back onto the o2 wires and use them. Since I happened to pull an auto m50 harness in the boneyard yesterday here is a pic of the wire colors for the o2 sensor plug.
            • Slider
              • Jan 2013
              • 10
              Awesome, thanks!
              • M3PO
                • May 2012
                • 537
                Yep, one is O2 (four wires), the biggest one plugs into the trans, not sure on the third.
                • M3PO
                  • May 2012
                  • 537
                  PS. I didn't have to do anything about a neutral safety switch.
