Euro S50B32 with E34 Pan - Does oil pump need changing?
  • Z2TT
    • Feb 2014
    • 51
    Hi.
    I'm doing a S50B32 EURO into an E30.
    So far I have on the way a E34 525i oil Pan and Pickup setup.
    But I have read threads that with the B32, you cannot use the oil pump off it, is this true. and in that case will any M50 oil pump be required?
    Further to this I went through a thread which mentioned that some people have had to cut their fins on the E34 525i windage setup, is this something I will have to do and will it affect reliability of the engine much?
    Do I re-use the S50b32 sprocket on the M50 Pump, or Do I just put the complete M50 pump in and it will bolt upto the E34 525i pickup setup?
