I have an E30 M3 Gauge Cluster should i use that with an S50? since it has a higher RPM gauge than the M20 gauge.
Also can the Stock M20 clutch handle a modded S50?
Will the Wiring diagrams posted for M50 be the same for an S50? The more i read about the wiring and seeing as teh wiring is a major turn down of this project i might just buy the treehouse adapter. I know its so cheap to just do it your self and ill praobably end up doing it that way once i get in there. But ive had an E30 apart with all the wiring and i know what a nightmare chasing electrical problems can be. Eliminating the problem with an adapter made by someone who knows about this stuff might make this alot less painful
also Do i have to use a different brake booster? If i dont is it easier to just use a different one like the 320i or something? What are teh options because we have a 318i and a few 2002 parts around. Id like to see if they will work before going and buying one
