This pertains to an S52 converted to OBD1 that has been swapped in my 86 ETA. Had a forum member come over to do the wiring today and the car runs and drives which is great. The problem is that the tach doesn't work and the heater fan doesn't turn on. The tach has jumped up to 1k rpms a couple times right when I start it but then it goes down to zero and doesn't move. We checked continuity for the tach signal between the gauge cluster and the c104 pin (good), and between the c104 pin and the c101 (good). The speedo works on the stock eta cluster and an "i" cluster I have but the tach doesn't work in either.
Any ideas on the tach? Also, any reason you can think of that my heater fan isn't working now but it was before?
