Stripped sump thread.. help :(
  • JordsProject
    • Dec 2014
    • 21
    so today i was fitting my e34 oil pan to my m50 and my last bolt i was using wasnt tightening at all, so pulled it out and what do you know. its stripped the thread. So i was wondering is the last bolt actually needed? it has 23 other bolts in it plus i used Permatex Ultra Black so that would glue it down. any insight? cheers :)
  • M3PO
    • May 2012
    • 537
    Tap it to the next size up.
    • AndrewBird
      The Mad Scientist
      • 11898
      Helicoil it. Then it will never strip again. I did all my valve cover holes as several stripped. It's all good now.
      • noid
        • 1536
        Do it once and do it right, timesert it.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • NC325iC
          • Mar 2004
          • 6565
          helicoil it, if you cant find one at a store go to a quick lube place.... trust me theyll have it
