Everything is working and motor is running, but I can't get the coolant to bleed. I have aux gauges so I can keep a close eye on temps. I filled the system with heater controls on full. When the car runs, it gets up to temp and the thermostat doesn't open, the temp just keeps climbing.
Everything is new. The motor was just built from the block up. Stewart pump, koyorad 48mm aluminum radiator, 16" spal pusher, new hoses, new expansion tank, aluminum thermo housing, and a behr 88c thermostat.
First I thought it might have been a bad thermo so I exchanged it for another new one, same issue.
The vents were initially blowing cold, now they blow warm, even with the motor at ~215-220F as indicated on the aux gauge.
I've revved it a little, driven it around the block (which has some steep inclines and declines) and it doesn't seem to help.
Yesterday, I got it up to temp, then it started getting hot, so I shut it down. As it was cooling down, I heard the thermostat open with a ping, coolant drained from the expansion tank, then "click" it shut again.'
Lower rad hose is not getting hot.
Any ideas??? I'm getting frustrated. I've never had this kind of trouble while bleeding coolant before.
