Newly swapped, odd issue
  • glucklich21
    • 1912
    Hi guys, so I got my M50 in my car and ran into an issue that's leaving me scratching my head.
    With the MAF is connected, the engine starts, then dies instantly. When the MAF is not connected, the engine starts just fine, but an obvious check engine light is illuminated. Idle is spot on and other than being really rich (O2 isn't installed) it runs perfectly.
    So MAF connected:
    No Fault codes other than one flash indicating fault code # "1" -wtf
    Video of this ^^^ is here: https://www.youtube.com/watch?v=Ap-m...ature=youtu.be
    MAF disconnected:
    Fault code # 1211 -bad DME
    The hell is going on?
    Here's a vid of it running with the maf disconnected for shits and giggles
    It was suggested on E30tech a massive vacuum leak, but all my hoses, gaskets, etc are good. The hose running to the ICV is clamped, silicone'd, and ziptied. I'm kind lost. Ideas?
  • glucklich21
    • 1912
    Bump
    • Rook12V
      • Nov 2011
      • 93
      Tried another MAF? When you disconnect it, it goes to sort of a default set of parameters. If its plugged in and won't run, try another maf.
      • glucklich21
        • 1912
        No I didn't. I'm always apprehensive when it comes to changing out sensors due to the experience I had with my S50. A bad ground inside of the harness left me chasing ghosts with sensors for two years before it was finally sorted. That said, I'll see if I can find one to try out.
        • glucklich21
          • 1912
          Since I couldn't source another MAF this weekend, I cleaned mine with some "CRC Mass Air Flow Sensor Cleaner." That resulted in my car idling with the MAF plugged in albeit very rough. I was able to run it like that for a few minutes and retrieved a fault code 1215 aka a MAF code. So I ordered a new one and that should be in by the weekend. Fingers crossed!
          • brecken
            • Jul 2014
            • 8
            Did you solve this? I'm having the exact same issue with my s52
