Hi mates!
I'm still in the swap process from the m50 to the euro s50 but I recently found something that is grinding my gears...
The engine I bought came without a transmission,so I found a 328i one,but it came with the small flange,so I ended buying another one out of an e36 325tds and fitted it to the engine.
But got some troubles with it
-The bolts that attach the tranny to the gearbox won't be aligned totally and the gearbox is currently with some offset.
-I've shimmed quite a LOT the exhaust motor mount trying to get solved the issue,and kind of sorted it,but definitely not happy running 8shims on the mount.
Any thoughts?
thanks in advance!
Any thoughts?
thanks in advance!
