Breaks issue
  • spoolin13
    • Jan 2015
    • 16
    Breaks issue
    Yes I know I spelled brakes wrong...
    I got this e30 that was half swapped.. gone through it and fixed everything up BUT the brakes. I believe its a IX booster with a 7 series MC from what I can tell. I cut it but im not sure if it was not enough or to much.. The brakes are compressing and feel normal but are taking little bit for them to return. What could be causing this? Should I cut the shaft more? Did i cut it to much? Any help would be great.. Thanks!
  • spoolin13
    • Jan 2015
    • 16
    help
    • spikemd
      • Apr 2015
      • 7
      Did you flush the fluid? Any leaks? Check the pedal when it isn't connected and be sure it isn't binding. Are the calipers compressing properly?
      1985 E30 S52, OBDI, E36 suspension
      www.e30s52.com
