e30 M50 Swap Throttle Cable
  • CrankYankers
    • Jul 2014
    • 13
    I have the e34 throttle cable for the m50 swap in my e30. Well we rigged up the end of the throttle cable to the engine. It snapped on us, so I need to understand how this is suppose to attach to the engine side. I've looked at realoem.com and other diagrams and I can't figure out the parts I need in order to connect the throttle cable to the engine.
    Any help would be appreciated.
    Thanks!
  • mpowerful
    • Jul 2013
    • 1273
    There is a rubber grommet that goes through the stationary bracket on the throttle body. The cable end has a plstic clip that goes around the cable and the cable stay metal cylidnder snaps into it. That plastic pieces then snaps into the square hole on thebthrottle itself.
    • SmokeE30
      • 1730
      you usually have to adjust the cable to the max and bend the brackets on the TB a little bit to get it to work as well.
      Shawn @ Bimmerbuddies
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      bimmerbuddiesllc@gmail.com
      • JRKOUPE
        • Dec 2004
        • 3159
        after years of reading about 24v swaPS...
        this is the first time I ever read this....
        and its exactly what we did....
        works great.
