Sounds like a power/ground issue at the harness connections not the DME itself....
					Stumped - S52 OBD2 no start (resolved)
 Check Us out on Facebook
 Full Product Line Tuning
 Grounds all test fine and the dme has power at the right pins. Even took a dremel with wire wheel to all ground connections to be on the safe side.
 Pretty sure the harness is fubar.
 After some further investigation I found voltage at all sorts of weird places on the harness where there should be none.
 The only way this makes sense is if there is some serious shorting in my harness.
 Haven't been able to find the short yet, next I need to remove the intake manifold (again!!!) and pull the harness.
 I have another harness on the way, so I'll probably just pull the old one and figure out what went wrong later.Comment
 Got the car started last weekend.
 After removing the intake manifold to replace the harness I decided to test the injectors while I had it all apart.
 No matter what I tried I couldn't get the injectors to open.
 Lo and behold, it turns out that rebuilt injectors can stick closed if they sit around for months.
 I sent them back to member justXtreme who kindly sent me a spare set he had around to get me back up and running quickly.
 Now the car fires right up! Apparently the voltage weirdness I encountered isn't a problem.
 My rebuilt injectors sat for like two years and one of them stuck closed. OK Injectors told me that they use a different lubricant during the rebuild process if they know the injectors are going to sit. Apparently the stuff they typically uses will stiffen up causing the injector to stick.
 Good to know thanks.My rebuilt injectors sat for like two years and one of them stuck closed. OK Injectors told me that they use a different lubricant during the rebuild process if they know the injectors are going to sit. Apparently the stuff they typically uses will stiffen up causing the injector to stick.Comment
