Is this right?
  • acolella76
    • 2950
    Is this right?
    Got my pistons back from the machine shop and I noticed that the wrist pins are about 0.125" shorter than the snap ring grooves. I know the machine shop didn't mix the wrist pins up, and I doubt the person I bought them from mixed them up. But is this really normal? I know the wrist pin doesn't move side to side... just seems like a lot of play.
    -Alex
  • spdracrm3
    • Sep 2009
    • 959
    they should be able to float but not that much ,it also means the pin is not fully supported by the bore and may wear a grove and then not float properly/bind
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • 328ijunkie
      • May 2007
      • 3961
      Somethings going on...
      Check Us out on Facebook
      Full Product Line Tuning
      • acolella76
        • 2950
        Dave do you have any S52 pistons lying around? tried to order a new wrist pin to measure. Apparently you can't order them and the dealership couldn't even give me the part number.
        I'm starting to realize that a stock rebuild on these motors is really uncommon. Or just undocumented.
        -Alex
        • 328ijunkie
          • May 2007
          • 3961
          Yes i do. Wrist pins are sold with pistons from B<W
          • LJ851
            • 7919
            The only time i have seen a piston with circlips and that much end float resulted in a destroyed piston from the pin hammering the circlips.
            I'm used to seeing several thousandths of an inch end float on a pin like that.
            Lorin
            The M30 is God's engine.
            • acolella76
              • 2950
              Do they have wrist pins and do you want to sell them to me for cheap? :D:D I'd rather not spend money on new pistons considering I just had the valve pockets cut on these.
              Yeah that is what I figured. Dang.
              I wonder if these pins are from an M50 and maybe the PO got them mixed up
              -Alex
              • 328ijunkie
                • May 2007
                • 3961
                Txt/call us
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  Sorry for an unrelated question, but:
                  I'm guessing you cut the valve pockets to retain full function of vanos with those cams? (rather than shimming the vanos)
                  Shadetree30
                  • acolella76
                    • 2950
                    Yeah, the cams aren't crazy (just regrinds) but the head was skimmed past BMW's spec so it was a little close on both sides. So since I couldn't find any thicker OEM gaskets for the S52 I figured cutting the pockets was the best option.
                    -Alex
