I have a few issues I have before starting the car today. So first I want to make sure I have the right stuff wired up. I'm a noob when it comes to cars and the Army hasn't helped too much with PMCSing vehicles when I was enlisted :P. Any help would be much appreciated though.
Issue#:
1. Is this the correct cable on the throttle position sensor? It's the only 3 prong cable that wasn't labeled from the previous owner. I can see the colors on the wire so if someone has the correct color I should be able to find out where it goes.
Or is it supposed to connect to here at the oil pan?
2.Where do these two wires connect? Is it the two connections on the fuel rail or one on the fuel rail and one on the solenoid? Keep in mind my Exhaust only has 2 OBD sensors and I don't think they will reach the ones on the fuel rail.
Here is a picture of the solenoid that has nothing connected to it.
Here is a picture of the fuel rail that has two connections that match up.
3.Is this where the oil temp wire goes to?
4.Where does this red wire go? I tried connecting it to a positive terminal behind it, but it started smoking a small wire just a bit in the dash when I turned the power on from the ignition. Immediately turned off the engine and figured I connected it wrong. Anyone know where it goes? For some reason I'm not getting any power to the fuel pump and I believe this red wire is the reason.
Issue#:
