Driveshaft center bearing design
  • BlackSpeed66
    • Apr 2008
    • 624
    Well I got my s52 started in the car last weekend. Started on the first try! :D
    I'm getting ready to install the driveshaft, which is a 325e "big guibo" unit. I had ordered the center bearing assembly for the type of car the driveshaft came on but recently discovered there appear to be two different types of bearings - early and late. My car is a 3/87 build so it is an "early" model. After doing a test fit of the front driveshaft, the mounting ears on the "late" bearing assembly are shorter than the holes in the body, so it will not reach "across" the driveshaft tunnel to bolt up.
    Has any one used the "early" bearing with the later driveshaft successfully? I'm hoping the design change is just the mounting points on the body, and that it will bolt up like the original. From what I can see on realoem.com, the sizing of the bearing itself seems to be the same between the two.
    Thoughts?
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '95 Jaguar XJR-6
    '02 Range Rover 4.6 HSE
    '98 Disco 1
  • FredK
    • 14762
    You just need the early bearing support. The bearing diameter is the same, but the early bracket has wider ears.
    • BlackSpeed66
      • Apr 2008
      • 624
      Best news I've heard all day! Thanks man!
      -Geno
      '87 325is (s52'd)
      '95 525iT
      '95 Jaguar XJR-6
      '98 Disco 1
      • M3PO
        • May 2012
        • 537
        Yep, I had this problem and had to order an early bearing. Part # 26-12-1-225-152
        • BlackSpeed66
          • Apr 2008
          • 624
          Yep, it so happens I had a spare early bearing, NIB - in my parts bin. got the old 'new' one off and put the early one on. Everything bolted up like it was made for it!
          Next up is sorting out my cooling fan situation...
          -Geno
          '87 325is (s52'd)
          '95 525iT
          '95 Jaguar XJR-6
          '98 Disco 1
