M52B28 - OBD1 or OBD2 - Which Management System and Tuner To Use
  • KI4UJO
    • Jun 2011
    • 642
    First off, yes, I know its been covered many times. I've read most of those threads to the point where I don't really know what's best.
    Currently, the car has a M50B25TU (Vanos) with a cracked block. So, I already have everything (minus the chip) in order to run the car with OBD1 management. Also, I have a complete 1997 528i as my M52 donor.
    Basically, my question(s) is this: What should I use, being that I have both management systems? I like the idea of having the OBD2 diagnostic capabilities, but some make OBD2 seem like a large hassle. Also, depending on which system I wind up using, who should I use for an ECU flash/Chip? I just need some advice after reading countless threads on OBD1 vs OBD2.
    IMG_0145 by Jonathan Martin, on Flickr
  • 328ijunkie
    • May 2007
    • 3961
    Typically speaking if you already have the M50 stuff most people stay obd1 although its arguable that its the best choice. Im obviously biased in many ways. ;)
    Check Us out on Facebook
    Full Product Line Tuning
