Adding Air Conditioning to an s50/s52 swapped car
sigpicGrind it till you find it.Comment
At the point of putting mine all back together at the moment.
Just fitted the compressor and wow...there is zero space for engine movement. Probably 2mm space at most!
how does everyone else go with space there? there might be a bit (~3mm) of movement for my radiator if i pull it in really tight to the core support with some safety wire.RHD OBD2 M50b25 turbo build thread:
http://www.r3vlimited.com/board/showthread.php?t=384800Comment
So you just the only thing you use off of the E36 is the compressor and the connections at the compressor? Condenser, evaporator and drier are all E30 still? Trying to make sure because I have the entire E36 donor car with working A/C and don't want to get rid of anything I will need.Comment
Everything is e30 except the two hose connections on the compressor and the compressor itself. The only thing you might want to grab from the car is the connector on the compressor. I can't remember if you have to splice that into the e30 wiring or not.
reviving this thread because despite my searches i've found no answers to this the clearance on the ac compressor. question. I've got "OEM" spec revshift motor mounts which are great in terms of clearance thus far but i've not driven the car yet and i'm worried about the motor moving into the rad. given the 4mm clearance. Is this acceptable or do i need to lose the 3 row mz3 rad for a few more mm?Comment
If your motor moves more than 4mm then I'd be concerned.sigpic
4 doors.. so much room for activities!
IG @bluebombr
Transaction Feedback:
http://www.r3vlimited.com/board/showthread.php?t=323622Comment
Great write up, I am about to tackle this project. Just realized you are a fellow Austinite, would love to see your car in person (If I haven't already around town)Comment
You should come out to one of our local meets, theres a decent amount of local e30s in town, plus I'd love to see a touring in person!Comment
Yes I was weak... let me know when you guys have a meet up. I just picked up a different german car that is drive-able. Maybe it can pass for an e30 while I'm finishing up my real e30.Comment
Yeah man, I'll shoot you a text next go around.Comment
