M52 oil pressure light hangs around after starting
  • Gruelius
    • Oct 2009
    • 298
    Hi all,
    When I start the m52b28 if it has been sitting for a few days it takes around 2 seconds for the oil light to disappear. Is there a drainback valve or something that might have failed?
    It runs quite well, but it had been getting 15MPG cause of a huge vac leak (plastic valvecover had a chunk missing under one coil pack) and a bad ecu while the P.O. had it so it might be a bit worn. Engine and car was also not looked after by past owner
    Thanks.
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
  • 328ijunkie
    • May 2007
    • 3961
    The two orings on the oil filter housing cap need to be replaced.
    Check Us out on Facebook
    Full Product Line Tuning
    • Gruelius
      • Oct 2009
      • 298
      Sweet, makes sense. The filter kits I got for the m52 only came with the larger oring, will get the lower one separately in my next parts order.
      Thanks!
      89' 318i
