Bleeding the system with the expansion tank mounted low?
  • Slider
    • Jan 2013
    • 10
    This on a 1987 E30 with an m50, e36 m3 radiator and e36 expansion tank. Couldn't mount it to the radiator, no room. It's mounted 6 inches or more below the factory location which is normally mounted at the top of the radiator.
    What would be the best way to bleed, I do have a compressor and one of those fancy vacuum bleeders that can be hooked up to the expansion tank and then filled.
    Also as far as bleeding without a vacuum bleeder, is it possible to bleed it through the factory bleed point or is it to low? If it is to low what's the best option to bleed it. Unhook the small hose from the top of the radiator and let it bleed out of there?
    Thanks!
  • AndrewBird
    The Mad Scientist
    • 11898
    That's notit going to work with it mounted there. The expansion tank is going to fill completely full before the rest of the system is full. You literally won't be able to put enough coolant in. Trayck needs to be the highest point yI the system.
    • Wanganstyle
      • 2828
      Thanks!
      remove it and throw away the expansion tank if you wish to put it in a place it cannot function properly.
      purchase the proper expansion tank to match your body if you wish to not melt your engine
      • Slider
        • Jan 2013
        • 10
        Thanks! That explains why it was such a pain in the butt bleeding it. Looks like a late model e30 expansion tank is the best option.
        • M3PO
          • May 2012
          • 537
          LOL, you completely defeated it's purpose.
