changing the distance of my injectors (E3024V)
  • King Mufasa
    • Sep 2012
    • 530
    Hey guys, might be the wrong place to ask lol but am planning on turbo boosting my 3.0 M52. Im going to put ITBs as well.
    as for the ITBs I can keep the stock location and angle of the injector but it will take a lot more work.. it will be easier if placed a bit higher upstream while still maintaining the nuzzle parallel to the airflow stream.
    since I plan on turbo boosting this engine and I'm working on setting up the ITBs I was thinking well al be using bigger injectors and knowing that if you put a big injector too close to the valve, there's not enough time for the fuel to mix with the air and not to mention the displacement is only a 3l.. I thought maybe move it upstream a bit but how much more is unknown..
    Moving the injector farther away from the valve allows more time for the air/fuel to atomize properly.
    Question is:
    Is there a known formula to use to calculate the distance?
    I read some where that a good compromise is a inch or 2 what say you..
