I bought the harness out of 05/94 build 325is auto along with the matching 413 RED label ecu. Doing research on pin outs for c101s and X20s I came to the conclusion that there are several different pin-outs for the x20. My only main concern about this is pin 7 on my harness is Green. From my understandings this means the car had ews installed, but I find this hard to believe since the car came with a 413 red label ecu.
So the real question is, does this harness and ecu have ews or not. If it does have ews, Im assuming it would be ews 1 and ews 1 apparently can be bypassed by getting an older 413 red label ecu.
Any help with this would be greatly appreciated :up:
Thanks, Jon
So the real question is, does this harness and ecu have ews or not. If it does have ews, Im assuming it would be ews 1 and ews 1 apparently can be bypassed by getting an older 413 red label ecu. Any help with this would be greatly appreciated :up:
Thanks, Jon
