Not another E30 M52 swap
  • 4DR_Lou
    • Jan 2011
    • 158
    Did some cleaning today... I plan to build a DIY hot tank this coming weekend to clean the oil filter housing and other parts I hope it works
    1990 325i - Current Project
    2007 Triumph Speed Triple 1050
    • 4DR_Lou
      • Jan 2011
      • 158
      Also got this today, locally for $120.. Only one small crack :)
      • 4DR_Lou
        • Jan 2011
        • 158
        I recently received my mint engine and trans mounts from r3v member tally159.. Great seller, fast shipper... Thank you!
        To do list:
        Send out ECU to have EWS deleted
        Engine and Trans refresh
        M52 engine wiring to E30 chassis wiring
        5lug swap
        Sort out AC... Must have AC :hitler:
        • 4DR_Lou
          • Jan 2011
          • 158
          Cleaned up the ZF real good
          My current struggle lol
          reference: http://www.bimmerforums.com/forum/sh...ng-chain-cover
          • 4DR_Lou
            • Jan 2011
            • 158
            Started looking at the e36 m52 engine harness. note: Left plug is the X20 and the right plug is the X6031
            So far... I still need to confirm the wiring layout.. and more to add... I will keep EWS too.
            Reference: http://www.r3vlimited.com/board/showthread.php?t=244469
            Updated picture
            Saw this a couple of days ago... I'm more honored than jealous to see one :D
            • 4DR_Lou
              • Jan 2011
              • 158
              So I went to get the ccv tube welded to the e34 dipstick tube....
              it turned out like shit considering it was done by a muffler shop!
              i also found a pin hole in the welds... this "professional" welder dude also messed up the area where the O-ring sits(see pic).
              I need a replacement e34 dipstick tube. Please let me know if you guys have an extra to sell.
              • DesertBMW
                • Aug 2011
                • 1040
                E34 dipstick will catch on that hole, I got better solution to this:
                • 4DR_Lou
                  • Jan 2011
                  • 158
                  Good idea, Desert. :D Thank you!!!
                  Improvising from your solution... How about drilling a hole and fit in a through wall-fitting instead of JB weld ;D .. I should have done it!
                  Example 1: http://www.mcmaster.com/#tank-fittings/=zn6vny
                  Example 2: http://www.ebay.com.au/itm/Bulkhead-...-/151820778799
                  *** The above links are just examples*** Please measure your hose size if you try out the route mentioned above.
                  • 4DR_Lou
                    • Jan 2011
                    • 158
                    update.
                    I received some electrical pins and m20b25 pin housing from TMS, yesterday.... FYI, TMS orders from the dealership then ships you the goodies... I could have just gone through the BMW dealership near me.. Only if I knew.
                    This is all I got done yesterday.. Pulled the Activated Carbon Canister from the trunk and Fuel Pressure Sensor from the passenger side wheel well.
                    • 4DR_Lou
                      • Jan 2011
                      • 158
                      got a new toy :giggle:
                      • 4DR_Lou
                        • Jan 2011
                        • 158
                        The weather has gotten warmer! It's time to continue this prolonged project
                        I have also been shopping around for a clutch/flywheel setup. So far, I'm sold to UUC's product SKU:B1-A-OE. Any other suggestions?
                        Stage 2 Lightweight Flywheel for '92-'99 E36 3-series and M3, E34/E39 5-series with 6-cylinder M50-series motor OPTIONS: Stage 2 flywheel only; + Performance Organic clutch; + UltraSmooth Cerametallic; + genuine BMW M5 clutch; + MultiPuck Ceramic clutch; + Segmented Kevlar.
                        • 4DR_Lou
                          • Jan 2011
                          • 158
                          finally got rid of the donor car
                          next step was to pull up my E30 onto the drive way. front valance purchased locally
                          received harness cover, ecu mount, and coolant temp sensor from Markertmotorworks.
                          picked up this wheel. love it so far
                          EWS II and diagnostic wiring
                          • 4DR_Lou
                            • Jan 2011
                            • 158
                            Flywheel and clutch set up finally arrived from UUC Motorwerks
                            • Yezus_Krys
                              • Feb 2016
                              • 80
                              Your car is exactly where mine needs to be except I have the M52tub28
                              • 4DR_Lou
                                • Jan 2011
                                • 158
                                I prefer to take my time on things. maybe you should too? ;)
