P/NO for earth straps/grounds
  • Tedford
    • Sep 2015
    • 33
    I've been looking all over the internets with no luck, the only P/NO I can find is for the hood strap which I don't need. I'm looking for the part number for the thicker earth strap on the driver side of the m50, or if anyone offers a full pack to replace all the grounds I'd even go for that. Are these parts commonly available these days? Would I be able to contact a dealership to source these parts(preferably without getting raped too hard)?
    Or if anything do I even need to use an earth strap? Can I just use a normal cable ground?
  • f4tj0n
    • May 2013
    • 411
    Contact them, I guess the lengths are different for a swap car. Top quality stuff!
    • george graves
      • 19996
      I remember my red top needed an extra long ground cable. Got one from autozone - the clamp broke off after 3 months. Bavrest one looks solid. Some people say it's a sin to both crimp and solder.. I'm not sure why people say that. I'll ask some guys that know more then I do (guys that do electrical engineering for the military and high power stuff).
      Originally posted by Matt-B
      • 328ijunkie
        • May 2007
        • 3961
        Soldering in OE applications is nearly unheard of for cost/relilabilty sake, but on higher gauge wiring (batt cables) you will see solder+crimp from the factory.
        Check Us out on Facebook
        Full Product Line Tuning
        • M3PO
          • May 2012
          • 537
          Soldering can make the wires brittle due to the heat.
          I have one of these and it works amazing:
          • AndrewBird
            The Mad Scientist
            • 11898
            Fairly certain it is #6 here:
            http://www.realoem.com/bmw/enUS/show...diagId=12_0364
            Email Steve at BluntTech at sales@blunttech.com and he will give you a quote.
