Pin out question (pin 14 to pin 14)
  • ST1G
    • Oct 2012
    • 6689
    Okay, I'm trying to wire up this s52, using a 1998 harness to a 1990 325i. It was going well till pin 14 (black/white) on the c101 is suppose to go to black white pin 14 on the s52 harness. Well the s52 harness is empty at 14 and I can't find where that wire would be or what color it should be on the s52 side. It should be the oil level fault set. Not sure what to do, I've spent an hour searching and reading and I'm not sure why I can't find info on it.
  • 328ijunkie
    • May 2007
    • 3961
    Rewriting an obd2 harness isn't the same as OBD1, you need to search more specifically
    Check Us out on Facebook
    Full Product Line Tuning
    • luckysnafu
      • Jun 2008
      • 262
      Check the wiring diagram links in my sig, they should help you figure out where that pin goes.
      M/S52 Wiring Diagrams
      Z3M S52 to late model 325i wiring diagram
      M52 to 318is wiring diagram
      • ST1G
        • Oct 2012
        • 6689
        Wanna tune my ECU? k thanks.
        Thanks for the point in the right direction.
        Awesome, that's exactly what I was looking for.
