Need help, ! 318 rad swap into m50 car
  • Vincer325ei
    • Mar 2014
    • 488
    what do you guys use for hoses for a m50 with a 318i rad! Ive searched high and low. Neef before h2oi !!!! Or Friday because vacationing till the 1st
    Need the hoses!!!! Yes its a e30
  • jt223539
    • Apr 2011
    • 139
    I can't remember which hose I used, but it is one of the e36 325i radiator hoses. You use two of the same hose, And then trim them both to fit. There is no hose that I know of that fits without any modification.
    • jt223539
      • Apr 2011
      • 139
      Also just found this thread:
      There are quite a few ways to skin this cat, really just have to see what hose you can find first.
      • Coupelx
        • Oct 2013
        • 169
        I used the e36 m50 upper and lower hoses. trim both as needed. at the engine side of things.
