M50v in my 86 eta-
Ive been chasing this for awhile now. It originally only did it when the engine was cold, when warmed up it was fine. It has now started occasionally doing it when the car is warm. once you come to a stop the idle will work its way down and settle out. The speed sensor input is hooked up and working obviously. Pulled codes and only got an 02 sensor code, which is weird since it is somewhat new. But I dont think that would explain the idle issues while cold? all vacuum lines are new along with any and all orings and i cant find any leaks anywhere. ICV is clean.
Any ideas?
Any ideas?
