Once and a while when I start the car the cluster indicators light up as shown in the picture and the voltmeter shows that there is no charge happening. I blip the throttle and the indicator lights turn off and the voltmeter shows a charging voltage.
The problem does not return for a while and there is no common clues as to when it happens. Engine could be cold or warm, outside temperature cold/warm/hot and it doesn't matter if it is raining or dry.
Belts don't feel loose so other than suspecting the alternator to be dying does anyone have any suggestions as to what is going on?
TIA for any info.
TIA for any info.
