M50TU 1221/1222/1264 codes, surging idle, no leaks...
  • kronus
    • Apr 2008
    • 13032
    No leaks I can *find* find, that is.
    Just put a bog standard M50TU into a 318is, and having trouble getting it running right.
    It is throwing a 1221 O2 sensor code, although internet suggests that this can be basically anything, and it is having a surging idle issue.
    Did the following diagnostics..
    - pulled booster vacuum line, plugged, retested, no change
    - pulled purge valve vacuum line, plugged, retested, no change
    - smoke test - no smoke out of anywhere in the intake plumbing (injector seals, intake manifold gaskets, ICV hoses and plugs, TB, CCV hoses, FPR line, purge valve line)
    Ideas on what could be going wrong? I have a BAR appointment on Tuesday morning and would like to not miss it.
    monday update
    well, tuesday morning 2AM update
    spent the whole day fucking with it
    learned several things
    a) I'm not getting -5inhg vacuum at idle, I was just reading vacuum from a shitty place (CCV vac line to ICV-manifold tube). reading at the booster nipple, I get -20inhg
    b) I have really good leakdown or I'm bad at using a leakdown tester. readings were 0% 0% 3% 1% 0% 0%.
    c) I still have no idea what the hell is happening
    installed a new O2 sensor, and traced out the O2 sensor wiring to the DME. I was suspicious of the O2 heater, but after searching, it seems to be a crapshoot whether it's on or off at cold idle.
    jumpered the O2 heater relay, finally started getting different codes - 1264 (O2 heater circuit) and 1222 (some lambda exceeding possible trim issue)
    tried two ECUs - a stock 413 silver label and a 413 silver label with a SSSQuid stage 1 chip, with similar results.
    the current failure symptom is - after running for a few minutes from a cold start, the motor coughs and pops the 1221 CEL. Idle is wavery throughout.
    looks like I'm not going to BAR tomorrow :(
    cars beep boop
  • sublimation
    • Jul 2013
    • 155
    I had this code and my MAF was bad.
    • kronus
      • Apr 2008
      • 13032
      updated with troubleshooting results, but I don't feel any closer to an answer.
      cars beep boop
      • pandaboo911
        • 2070
        I cleaned the MAF with sensor cleaner before I gave it to you. It was working fine when I pulled it from my car.
        Unplug it and see if the car runs better
        • kronus
          • Apr 2008
          • 13032
          I think the MAF is fine - I tried another one and the car ran way worse.
          It does have a more even idle with it disconnected, though, but AIUI when that's done the DME goes into open loop and ignores the O2 sensor, the MAF and the coolant temp sensor.
          cars beep boop
          • pandaboo911
            • 2070
            Check voltage at the MAF with zero flow. Should be .4-.5 volts.
            Check your plugs to see if it's rich or lean.
            Lean could be low fuel pressure, bad fuel pump, clogged filter(likely), clogged injectors, blockage in fuel feed line, stuck open icv
            Rich could be stuck/leaking injector(unlikely) bad MAF(likely), bad fuel pressure regulator, blockage in fuel return line
            Did you ever open the valvetrain? The guy who did that motor could have timed it incorrectly
            • kronus
              • Apr 2008
              • 13032
              thanks! I will look at all those things. fuel is a not unlikely culprit seeing as the car sat for a few years.
              AFAIK the guy didn't pull the motor apart at all, but I don't know for sure.
              if he did there is also the possibility of the vanos being mistimed but I have no idea if the guy removed it
              cars beep boop
              • pandaboo911
                • 2070
                Well if the car sat there could be bad gas that has emulsified stuck in a line. Did you install a new fuel pump? Try blowing compressed air through the lines.
                I'm assuming you put a new filter too right?
                If a problem persists even though all the sensors work it's usually fuel or vacuum related since those won't show up on the ecu.
                Could be a bad knock sensor too and the car is running in limp mode
                • kronus
                  • Apr 2008
                  • 13032
                  I drained the gas and replaced the filter during the build.
                  Reset the ECU and put in a different MAF as a guess while I read about MAF testing. No difference.
                  cars beep boop
                  • kronus
                    • Apr 2008
                    • 13032
                    plugs look ok, maybe a bit lean
                    wouldn't a knock sensor failure have its own code?
                    dropped in a different (used) set of m50 injectors, same deal.
                    to recap, the symptoms
                    once car is hot, idling for less than a minute will lead to it violently stumbling once, throwing the 1221 O2 sensor code and having a rougher idle thereafter.
                    No code is thrown during driving.
                    Power feels normal until code is thrown, there is no misfire or hesitation.
                    The idle is normal until code is thrown.
                    things I've tried with no effect
                    replaced oxygen sensor with a new one
                    replaced MAF with a different used one
                    replaced ICV with a cleaned, working one
                    replaced injectors with known-good ones
                    replaced coils with known-good ones
                    replaced spark plugs with new ones
                    replaced fuel filter with a new one
                    replaced TPS with a known good one
                    checked manifold vacuum; -20inhg (in spec)
                    leakdown test; 0% 0% 3% 1% 0% 0%
                    smoke test; no leaks
                    reset ECU; no change
                    replaced ECU with stock-tune 413; no change
                    remaining diagnostics
                    meter out the TPS
                    meter out the MAF
                    monitor fuel line pressure
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13032
                      fuel pressure is 3.2 bar (46psi) at idle, which is on the high side of spec but normal.
                      cars beep boop
