87' 318i m50 swap, best tranny to run ?
  • Paulow
    • Oct 2015
    • 14
    Hi
    I'm about to swap a m50 in my 87' e30 powered by a m10. After a few researches, I've found out that it originally came w/ a 240 Getrag gearbox. Well from what i've firstly heard, it is a direct swap on the 24v engine but it ain't, cause 240s came w/ differents bolt paterns on m10 and m42.
    So I need to change my gearbox to fit the m50. The question is, which one to choose ? Would a 318is 240 need any mod to fit the 318i ? (Drivetrain, cross member..) or is it bolt on ? Would a 260 or zf be better ?
    The car will be daily driven and the engine nearly stock so i don't need a 300+hp gearbox, just one who can handle the m50 power in a good way.
    Any infos will help, thanks in advance
  • DesertBMW
    • Aug 2011
    • 1043
    getrag out of 1992-1995 325i would be the best match
    • M3PO
      • May 2012
      • 537
      I am partial to the ZF but that's because it was standard on the '95 M3 that my S50 came out off.
      • exhaust
        • Jun 2015
        • 411
        I'd agree that the Getrag 250 would be the best bet. It was originally paired with the M50 and will be cheaper than the ZF. However, I've seldom gotten a used 250 that didn't grind in second. The ZF is a more robust unit.
        • Paulow
          • Oct 2015
          • 14
          Thanks for answers guys. Can you tell me why would the Getrag 250 be a better bet than a 240 (from M42) ? It seems that a 240 w/ m20 flywheel, m20 starter and e36 325i driveshaft does the job pretty well however.
          • Paulow
            • Oct 2015
            • 14
            Early m50 swapped e30 w/ ZF320Z
            I finally found a cheap ZF 320z from a 328ci which is only 100k km. I do have some quetions however.
            Firstly, will a complete m50 clutch assembly work w/ the zf ? I do have the flywheel, so if it works I would only have to buy a clutch kit. I've seen that m50 stuff is 240mm rather than m52 stuff is 280mm so it might be ok, right ?
            Secondly, do you guys know if the original m10 brace will be able to welcome the ZF ?
            • M3PO
              • May 2012
              • 537
              I don't think the M10 brace will work. I think you need an M20 brace. My S50/ZF works great with the brace from my Eta.
              • Paulow
                • Oct 2015
                • 14
                It seems that the m20 brace doesn't sit a the best angle from what I've heard, are you sure it fits right ?
                • Mwishlist
                  • Jul 2013
                  • 505
                  Using stock M20/Getrag 5 speed trans brace here with my ZF trans and it bolted right up.
                  Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
                  • Paulow
                    • Oct 2015
                    • 14
                    Yeah that's what I finally discovered. So the plan is: e36 m50b25nv, m20 flywheel/clutch and gearshift linkage, e21 323i release bearing and tranny mounts, e46 328ci zf 320, e36 325tds driveshaft (same as 328i) and e30 3.25 differential. Sounds good ?
                    • M3PO
                      • May 2012
                      • 537
                      My only concern is the shift linkage. I think you need the shift linkage from a 328i or M3. The M20/getrag shift linkage won't work I don't think.
                      I have essentially the same setup (mine is an S50 and M3 clutch) and with the 3.25 I am at 4K at 80 mph on 205/45/16. Just an FYI.
                      • Miwi
                        • Feb 2015
                        • 45
                        Zf
                        www.MarkertMotorworks.com
                        Dyno Thread.
                        http://www.r3vlimited.com/board/showthread.php?t=327183
                        • Mwishlist
                          • Jul 2013
                          • 505
                          I'm using 328i shift linkage and it's right on the money.
                          • Paulow
                            • Oct 2015
                            • 14
                            Thanks for info M3PO, it sounds pretty good!
                            You guys rock, thanks a lot for helping. I'll definitely go for an E36 325 tds gearshift linkage, it is the same as 328i's and easy to find here in France.
