I recently picked up an S50 swapped car that has a 413 DME installed. I'm not sure whether or not it actually has an S50 chip in it as I've been unable to find any info on what the chip numbers for the M50 and S50 are. I know it's not too much of an issue to run it around on the street as it's running in closed loop and shouldn't have an issue hitting AFR targets.
My question is, do these newer ECU's with variable TPS still run open loop at WOT? I'm planning on taking this car down to Roebling this weekend and I'm concerned it's going to run lean if it's still got an M50 chip in it while running almost entirely at WOT in open loop. I'm sure the best solution would be to just buy an aftermarket S50 chip from somewhere, but I don't really have time at this point.
Dave, if you happen to see this, do you have any S50 chips on hand?
Thanks.
Thanks.
