I had my harness wired for me and I'm 99% everything is hooked up properly but I get no Check Engine Light when I turn the key on. I can't find a ton of info on this but the Cel light should come on when I turn the key right?
Info:
All other lights on the dash come on
1990 vert with S52 OBD2
Working (at least was when engine was pulled) swap tuned silver ECU
Cranks strong
Questions:
It was an auto Prior to swap, so I did the under dash wiring changes from auto to manual. Not sure if this may cause an issue.
There are some left over wires in the glove box from the old ECU. Is there any wiring that needs to be done inside the car?
					Info:
Cranks strong
Questions:
