automatic m50 question
  • h0lmes
    • Sep 2026
    A local junkyard is going out of business and offered to sell me a 95' m50, with 90k for 300 bucks if I pulled the motor. However, the car is an automatic and I am wondering how well the motor will handle high revs after being somewhat babied connected to an automatic all it's life. Is there any problem associated with this or am I just imagining things? Also, is this motor somehow different being an automatic or will a getrag 260 mount right up like all other m50s? Thanks.
  • puusitalo
    • Mar 2005
    • 21
    I would not worry about engine being connected to automatic transmission. You need to get flywheel for manual (M20 if using Getrag 260) and take a look at wiring more carefully, since there are interconnections between engine and gearbox ECU's. Worst case scenario would be buying manual ECU for engine.
    Petteri
    • Jason89i
      • Sep 2004
      • 875
      motor is the same. you will need a flywheel (as earlier mentioned) and clutch kit (dont forget to install the pilot bearing.) the ecu's are the same between auto's and manuals. however, there are a lot of wires on an automatic that you will need to eliminate and cap. cheers, jason
      • h0lmes
        Will I still need to eliminate and cap the wires if I buy a treehouse harness adapter?
        • Jason89i
          • Sep 2004
          • 875
          technically no.......but yes you will want to. the automatic trans has its own seperate computer. that whole bundle needs to be removed. most of the wires go to the trans, but some also tap into the engine ecu harness. carefully eliminate.
          cheers, jason
          • h0lmes
            cheers, jason
            So I can just cut them and heatshrink the ends then?
            • tjhartge
              • Jun 2004
              • 86
              yes you can.
              a step further, try and trace al the wires to junctions that bundled up together, so it is safer that way, and neater too
              there maybe 1 or 2 looped ground wires, if so, trace them back and see if it needs to be grounded
              • h0lmes
                I appreciate the help guys. I am sure I will have many questions to come.
                • erik325i
                  • Jan 2005
                  • 3567
                  Most people I know would prefer buying a motor from an automatic because it has been babied all it's life...
                  -Erik
                  • h0lmes
                    -Erik
                    Yeah, the more I thought about it the more it sounded like the good way to go.
