I am pretty sure that my 117K mile S50 has a blown headgasket. I've put a few thousand miles on it and never overheated it. I've got a new E36 rad, Stewart racing water pump, Spal fan in place of the aux fan, and a 80/88C switch. I have an aftermarket temp gauge to keep an eye on temps. It started to steam a lot a few weeks ago on cold starts and now the oil cap is looking milky. The coolant level is going down fast but I also have a leaky heater core. I read the Pelican DIY and now I have a bunch of questions.
1) Which gasket? Is OEM the only trustworthy one?
2) Head bolts? It won't see boost.
3) It's my only car right now so I don't want to send the head to the shop (weekend job) unless I have to. Is this irresponsible?
4) I have a liffter that sticks for a few seconds on start up sometimes. Clean and polish them? Replace that one? Replace them all?
5) Special tools. Best/cheapest way to get a cam holding tool? What about torx tool for head bolts?
6) I've heard the S50 has weak valve retainers. This engine will see a lot of high RPM track time soon. Should I replace them and with what?
7) "While I'm in there", I want to do some cams. Which ones? I want something that makes proven power but isn't outrageously expensive, ie the best "value".
8) I have VANOS rattle so I will be rebuilding it with the Beisan systems kit. Any tips?
