I'm in the middle of swapping the pan on a m50 from a e36 to an e34. I have a couple of questions the bracket that's bolted to the main cap that holds the pick up tube. I know it has to be removed but I can't find the torque specs for the main cap. And secondly the windage tray that's bolted on a e36 motor. Do you leave that off since the e34 pan has one made in to it. Thanks in advance
e36 to e34 pan swap ?
I left the s50 stock one in and drilled out the one in the oil pan. Everything was pretty straight forward.CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
Instagram: @centerbarmotorsport
Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
The Fleet:
-1984 325ei Lapis
-1991 325ix Diamond
- 2005 X5 4.4i Black Sapphire
-1972 2002tii Fjord - SOLD 7/8/17
-1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
The Bike:
-1980 R100RS Inca
sigpicComment
^ I was modifying my pan anyway for better oil pick up, so it was simple to do while I had everything out on the table. It doesn't matter either way though neither is more beneficial then the other.CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
The Fleet:
-1984 325ei Lapis
-1991 325ix Diamond
The Bike:
-1980 R100RS Inca
sigpicComment
- S50 Swapped E30 1/1 Mineral White -@vaughnbannister on IGComment
