Can a late model cruise unit be used on an early model?
  • BlackSpeed66
    • Apr 2008
    • 626
    Now that I've completed my s52 swap on my '87, the late model coolant tank has taken the place of my cruise actuator. Seems the later e30s use a similar style actuator that mounts on a bracket off of the airbox housing. The wiring on the early style actuator on my car is not long enough to reach there so I'm wondering if a late model actuator and bracket can be used? I do remember reading the late models had a 'decel' option using the different switch on the column (nice to have but not something I need) but can the actuators be swapped and still retain my current functionality? I'm not sure what the end of the electrical connector looks like, but I'm imagining the late model units have a longer cable due to the different mounting location.
    Thanks!
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '95 Jaguar XJR-6
    '02 Range Rover 4.6 HSE
    '98 Disco 1
