Can I buy these fuel injector clips by themselves?
  • AllydNYC
    • Aug 2013
    • 350
    Spent some time searching and I couldn't find it. It seems like it's part of the harness. I rather not spend $16 on a set on eBay if I'm just looking to replace a couple of these, I can add them to order of other parts I'm ordering.
    I need the little metal pieces (bottom pieces in the picture) that keeps the fuel injector plugged in. Yes I know they look fine in the picture, it's not my picture.
    Thanks!
    E30: '91 318is - M52/ZF320 | Azev A 16X7.5 | H&R Race/Bilstein | Completely refreshed suspension/brakes/drivetrain
    An Associate/Bachelors degree is America's most overrated product
  • 328ijunkie
    • May 2007
    • 3961
    The bottom ones you only need a few of to be honest esp when OBD2. In a bind when there missing we just make sure theyre on cylinders 1, 3, 6 and the rest will stay because of how rigid the OBD2 fuel rail harness is. Its also alot less of a pain when you need to take it off. :P
    Check Us out on Facebook
    Full Product Line Tuning
    • AllydNYC
      • Aug 2013
      • 350
      Thanks man. That's what I was thinking about doing.
      Thanks for being so helpful around these parts.
