Installing Transmission
    I am mating up the E36 transmission to the engine after replacing the clutch/flywheel and there are a couple metal 'tins' that go between the two.
    I can't recall the configuration of the 'tins', does anybody know how the go or have a picture? Do I even need them? I was hoping realoem would have a diagram, but it doesn't show them.
    i didnt use any... i am not saying that this is the best way but i have had no problems without any of those heatshieldy things
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
      mike - there is one small set screw (10mm head i think) that goes on the exhaust side of the bell housing.
      install it, it keeps water, dirt and r-comp buggers out of the bell housing. the last thing you need is your fly open.....i mean flywheel open.
      cheers, jason
        Reviving an old thread because I search...
        My bell housing part of my G250 motor has a few holes in it. Is this bad? Do I need to find a way to seal the holes. There are two about a nickel large I guess, and I can literally see my flywheel through the holes in the bell housing.
          Are they legit holes? Or cast in openings, there's normally a couple opening in the bell housing were it mates against the block. Totally fine that those are open.
