Doing my s52 swap. Just dropped the pan to replace the oil pump, secure the nut, pan...etc. while there I removed the baffle and look into the cylinder from the bottom end and rotated the engine. I definitely hear air coming out of the cylinder between piston and cylinder. It's leaking by the rings... the engine has been sitting for 2 years... hard to do a compression test with engine out... video will come tomorrow.
Is it normal?
Is it normal?
