Timing my S50 help!
  • M3PO
    • May 2012
    • 537
    Timing my S50 help!
    So my head cracked. New head, port job, big cams, valve springs, etc. I pulled the valve cover after a few hundred miles to see how I did on timing because I think I ran the engine the wrong way doing it the first time. Is this "close enough" or worth redoing? Exhaust cam is a little advanced, intake a little retarded. The previous owner of these cams ran the exhaust 6* retarded to make the best power I believe. What say you?
  • M3PO
    • May 2012
    • 537
    No one can tell me? I think it's fine. Not worth doing again.
    • kronus
      • Apr 2008
      • 13029
      I used the timing blocks to do mine. I've heard of successful builds using a ruler to time the cams, but the builder set them to be in line with the ruler, not advanced/retarded like yours are.
      What you have amounts to eyeballing the cams, which is not likely to produce good results.
      cars beep boop
