Hey guys,
I've been experiencing some issues with my S50 Swapped 91 318is. Previously the car would not start, only crank. I rectified the problem by changing the DME to a 506 with a TMS S50 Chip. The car then started, only to die after I gave it gas. I noticed a massive vacuum leak in the Air Intake Rubber boot, and swapped it out for a new one. I started up the car again, it idled nicely around 1000. When I try to drive the car though, it will die after 20 seconds of light driving, or if i push it hard. Heres the catch though, The car will only start and stay idling if I wait an hour or so to start it again. If I try to start it right after its died, it isnt able to start.
Im assuming its either an electric problem or a fuel issue.. Its got a new fuel pump though.
Any ideas ?
To sum it up... the Car only starts if wait an hour or so to start it. Once I do, it idles nicely but dies when I try to drive it.
Thanks
Any ideas ?
Thanks
