My head gasket seams to be sligtly leaking coolant on the exhaust side at the rear end... probably something like this:
(Not mine)
The leak is very small, when the engine is hot it evaporates as it leaks...
Will check the compression to be sure that the cylinders are tight and would do as my local bmw shop recommendend: let is seat a entire night while pressurizing the cooling system...I'm not totally sure that it is a good idea... If it leaks elsewhere then to atmosphere, could it do any damage?
Else than this, engine run and start just perfect with no white smoke...
(Not mine)
