I bought a BAR'd 91 318i with OBD1 S52 swap from another member on here. I recently switched out the gauge cluster and noticed the previous owner took out the CEL bulb. I installed my new gauge cluster and drove about 15 miles when my CEL turned on. Had a local shop run the code and was told it was throwing a speed sensor code.
Long story short I traced the wires and everything looks good. I took the sensor off the diff and cleaned it. Anyone know what else I can check? Could it be the sensor is bad? Speedo/ RPM and all gauges work.
